I have around 400 miles so far on a TSDZ2 conversion on my Raleigh Mountain Tour Seneca. I would like to add brake cutout switches to the existing brake levers. I have tiny magnetic reed switches and magnets from prior projects making float switches that I can use on the brake levers so parts wise I just need the mating connector/ cable to the 3 pin brake cutout connectors (see pic) from the controller. Where can I buy it? I searched Aliexpress and all I can find is speed sensor cable for TSDZ2. Links please?
With the black lead on the common pin, I measured 4.19 and 4.65 V on the other 2 pins. Which pin(s) do I short to the common to cut power to the motor?
