Sorry to post as another person with tongsheng tsdz2 problem
I've had for over one year worked fine, on my 2nd battery since December working fine.
Then last week 30 mins into ride the motor cutout.
Was showing e06 error which is undervoltage.
Tried restarting. Same error etc
I turned off motor and cycled 30 mins. Later turned on and it started working again.
Then today it kept cutting out at random intervals, sometimes on flat sometimes going downhill (even though in mode zero off downhill) sometimes uphill.
By cutting off the display stays on but the motor stops assisting and normally goes to e06 mode after a few seconds
I've tried cleaning the connections but problem seems to still be there.
Not sure what to look at.
Assumption that it's not battery issue as it works fine for minutes after Not working and repeat.
Only extra info is I heard a click today just when the motor stopped adding assistance.
Is it likely to be a shortage?
