TSDZ2 OSF build - final walktrough help
Danielwj
Hey guys.
So tomorrow I really wanna send off the final ordering of this build, but im a little bit confused about the cabeling / PIN number. Because I live in Denmark i need to place the ordre all around the world to get the best price, and because of that I really just can't wait to see what shows up in the mail and then ordre the missing part (I need the bike running as soon as possible), so I hope you guys can help from the look of the links provided.
Motor: Tsdz2 350w 48v with a 17ah battery and a 5aH charger (Germany)
https://enerprof.de/motor-kits/motor-kits-48v/639/tongsheng-48v-350w-mittelmotor-display-akku-hailong-ladegeraet?c=106
Display:
Bafang 850c preflashed from eco-bike with OSF
https://www.eco-ebike.com/products/850c-display-for-tsdz2-with-open-source-firmware?_pos=1&_sid=b09c74023&_ss=r
Bootloader box for later upgrades of the display firmware
https://www.eco-ebike.com/collections/tsdz2-accessories-parts/products/850c-bootloader-box-plug-and-play-tsdz2-open-source-firmware-updater
'Motor firmware upgrade cable
https://www.eco-ebike.com/collections/tsdz2-accessories-parts/products/tsdz2-motor-firmware-programming-cable-with-6ft-usb-extension
Splitter cable for lights
https://www.eco-ebike.com/collections/tsdz2-accessories-parts/products/tsdz2-speed-sensor-with-y-adapter-and-light-cables?variant=31538867798098
Chain guide - roller wheel model
https://www.eco-ebike.com/collections/tsdz2-accessories-parts/products/chain-guide-for-tsdz2?variant=12784302489682
(I really don't know if I need it, but the bike is going to be build around is a MTB and if it turns out I need it, I would like to have It ready rather than have to wait 3 weeks)
Question number 1:
So far so good... what confuse me is the cabling, and the PIN number. Do I need a 8 pin to 5 conversion cable or a 6 to 5 pin conversion cable.. Is the one im going to order defined as a new or old version?..
Question number 2:
Do I need to ordre a 1t4 1t3 1t2 or 1t1 cable?
Question number 3: E-brake is this version the one I need? https://www.eco-ebike.com/products/hydraulic-and-mechanical-e-brake-sensor-and-magnet-for-bbs01-bbs02-bbshd-bafang-8fun-mid-drive?_pos=4&_sid=442a0b80b&_ss=r
Question number 4: Did I forget anything? :D
When finish I want to end up with a bike with brake sensors (hydraulic), head and back lights that can be turned on from the display, I will not be using a throttle, and for the start I will try to live without a temperatur sensor but if nessary I will Install it later on.
Thank you all for the help!!
