Hello to all, I own a TSDZ2 with board ‘2020’ installed with a Hubgear Shimano Nexus 8 and I intend to buy another TSDZ2 installed with a hubgear Shimano Nexus 7.
Hub gears cannot be shifted under load. I have 15 years practice of hubgears so I am used to release pressure when shifting.
Under high torque, the Nexus 8 simply does not shift and when you release the torque, it finally shifts with atrocious noise which make you suffer along the hubgear.
Unfortunately, the original board ‘2020’ version of the TSDZ2 (bought in Germany, assumed to be V2, 6 pins) have a very long delay (maybe 2 or 3 seconds) between the pedal torque release and the motor torque shutdown. This is too long to be easily manageable.
There was a shift sensor detector for the TSDZ2 which was adapted from the one for the Bafang with TSDZ2 plugs, sold by Okfeet. Unfortunately it was only available for 8 pins board (no throttle) and not for 6 pins boards and is yet no longer available.
After unconclusive exchanges with my reseller (Enerprof in Germany) I anyway bought a control board adapted for coaster-brake motor (while my motor is a ‘freewheel’ motor). Enerprof are among the few resellers (maybe the only one) which sells boards and motors adaptad for coaster-brakes (6 pins only boards).
This worked as with this board there is no longer any significant delay between the pedal torque release and the motor torque stop.
Though with this new board I did lost all the ‘smoothing’ of the former board, which was smoothing my irregular pedal torque. This is less comfortable but not an option. Also, I think this irregular torque aggravate the control board overheating problem.
I am interested to buy a new TSDZ2 motor but as I experienced frequent overheating of the control board while climbing and/or hot temperature, I may choose to use an OSF programmed board to alleviate the problem (probably alongside with cooling kit as sold by polish company ebikestuff.eu).
So I have a few questions :
1/ On the OSF, what is the default delay between the pedal torque release and motor stop ? Is it adjustable with the SW102 panel (or with another panel) ? Does someone have experience with OSF and hubgears ?
2/ Does someone know if the ‘2023’ original version of the board (V2 version ?), the delay problem is still existing?
3/ Can we find a gear shift sensor with plugs adapted for the TSDZ2 sensors? Some resellers sells gear shift sensor pretending they are adapted to the TSDZ2 but the plugs are the Bafang plugs, so this won't work.
4/ I’ve read somewhere that with TSDZ2 with SW-102 panel, the plugs are Bafang plugs, so can we adapt the bafang shift sensor?
I will much prefer a software solution than adding a failure prone sensor.
There is a thread on this site about installation on the TSDZ2 of a gear shift sensor:
Gear Shift Sensor for Tongsheng TSDZ2
