mbackc@gmail.com
- Joined
- Nov 17, 2015
- Messages
- 27
Hi folks...
I´m considering the possibilities of tuning the BBS-HD, by increasing the max current in the setup of the controller.
Im fully aware that there are certain risks connected to this. I´m used to short maintenance schedules on motocross bikes - where the lifetime on a piston is 10-20 hours as an example.
Increasing the current limit from 30amps would lead to increased stress on the nylon gear and possibly on the controller itself. I´m aware that 65 amps with an external controller have been tested with bad results: http://electricbike-blog.com/2016/03/01/my-bbshd-was-evil-and-it-deserved-to-die-a-horrible-death/
But would it maybe be possible to increase to a level in between 30 amp and 65 amps - without ending up with a disaster - if the unit is properly maintained ? A fixed schedule on nylon gear replacement could be introduced - based on experience.
The question is whether anyone have done it ? Luna cycles states that their BBS-HD is "hot rod programmed" - whatever that means...
How much more current would the internal controller be able to handle ?? Any ideas ?
Thanks in advance.
Michael - Copenhagen
Thanks in advance.
