cejar21640 said:
Many thanks for the response. What im going to do is wait for a bud of mine to come down with his throttle and put that on see if it works. But lets say the wires are reversed, how could i found out which wires are the same. And is it probable i could do this with a multi meter without splicing the wires. The reason why im hesitant in splicing the wires is that i would like to retain the waterproof properties of the connectors. Many thanks.
Yes, you can test without cutting into the cable, but you have to open the throttle body enough to touch one of the meter probes to the actual sensor leads inside it,
To just test for which wire is which, you'll need to be able to see which way the hall sensor is facing, so the order of pins can be determined. (the wire colors aren't enough because we suspect a miswire). If you can see the marking, it's on the bevelled side, so the pictures below show the order as it would be there. If you can't, you're probably looking at the flat side, and the order is reversed:
This diagram has the Bafang BBSHD throttle connection in the lower left corner, as marked on the male (pins sticking out). If your throttle uses this style, then it uses the female connector (holes for the pins) and then the red and black 6 and 8 wires are mirror-imaged from the picture.
https://custom-ebike.com/products/higo-mini-c-3-pin
I don't know what wiring order your system actually uses, but that's a common one.
The meter leads may not fit in the holes so you may have to use a straight-pin or needle to go into the pin and touch the contact, then touch the meter lead to that. If you have alligator clips on at least one meter lead, it will help you do this test with less hands.
If your system is different, you would need to open your old throttle to verify which wire from each sensor pin goes to which pin on it's connector, unless you can tell us which system it is and we can find a diagram to show what it should be.
Have paper and a pencil or pen handy. Draw a circle with three dots in it that looks like your throttle connector, as it looks facing you, along with a bump on the circle to represent the little plastic key mark. Draw a square with three lines off the bottom to represent the sensor as if it were facing you with the bevelled side (even if it's not).
Set the multimeter to 200ohms or continuity. Put the black lead on the first pin of the connector. Put the red lead on the pin of the sensor that equals the leftmost one of the bevelled side with the pins pointing down (like in the diagrams). You should get either a very low number (or beep), or OL on the screen. IF it's OL, that means no connection; the other two mean that's the connector pin that is connected to the sensor pin your'e measuring now.
If you get OL, move the red lead to the next sensor pin, and repeat again if needed for the last pin. Do the set of tests again for each of the connector pins to each of the sensor pins.
Each time you get a beep or low reading, draw yourself a line from the pin on the connector you drew to the pin you measured the low reading on, so now you know which connector pin is connected to which sensor pin.
If that matches the Bafang BBS diagram I posted above, then the connections are probably correct, and further testing as noted below will be needed (assuming your system uses the standard connection pinout). If it doesn't match, tehn you would need to alter the wiring to match it; this is delicate work inside the throttle (the leads break off the sensor quite easily, and heat can damage it).
For certain tests, like verifying the signal is valid and the right voltage range (which you probably wont' have to do), you'd also need to do this while also keeping it assembled enough to rotate normally and keep the magnets where they are designed to be (or else you don't get normal readings).
If that's not possible, you may have to attach an extra set of wires to the sensor, or the wires inside the throttle body before they reach teh sensor, to then touch the meter lead to. We'll worry about that after verifying the wiring.
