Given that wheel and tire sizes can be assumed to be the same,
as long as you have a typical bicycle, tha'ts generally true, but some are 96ers or 69ers where one wheel is a lot different ins ize, like my crazybike2 and sb cruiser trikes. that's why i mentioned it, as you don't specifiy what you're converting.
the real variable would be the controller's response and sensitivity to the voltage applied. I don't know how much of an issue that would be in real time. I presume that both wheels on separate throttles would have even variation based on the ability of the rider to manipulate the throttles.
yes, or different response if you want that--i used separate throttles on crazybike2 for front and rear specifically for the maneuverabilyt this allowed, as well as redundancy since they were totally indpenedent except for using het same battery sourc.e it had not only different wheel sizes but also different motors and different controllers, so this made performance a lot easier to make "ideal" by using two throttles than ust one.
on the sb cruiser trike where the wheels are side by side on the back of the trike one left and one right, i use a single control source (throttle if necessary, but it's normally the pedals that send cadence to the cycle analyst which then outputs a throttle voltage to boht controllers at the same time. at the moment sbc has nearly identical motors and controllers on each side, so they respond very similarly, but i have had quite the mismatch of parts over the years, and i'd just have to learn to counter any pulling to one side by steering inputs, until it was just second nature.
In either scenario of throttle configuration there will always be some differences in power applied to each wheel at any given moment, sometimes intentional, sometimes not. Assuming each wheel/controller operated on separate batteries, the charge level and things like sag, could also contribute to differences in power applied. Again, thanks for helping me understand the issues involved here.
most situational differences, assumign otherwise identical front/rear systems, will not make much of a difference to operation. it's usually when you have significant differences between the two ends of the bike that things can require some tuning of throttle to each controller after the split point to get htem to work as needed.
sometimes it still works fine even without that, even with major differences...just that one of the systems takes more of the load does more work than the other.
some 2wd systems are actually set up that way on purpose.
