Noobie said:
How do people find out about this stuff?
Experience, Research, Engineering backgrounds, and Asking a ton of questions on the forum.
The bigger battery should work, as long as it's amp output is at least twice the amp rating of either controller. Which brings up a point. Your battery's rated amp output must always be equal to or higher than the max output of the controller.
A two motor system can work, and sure sounds cool. If you want to build it just for the fun factor, go for it. But It has very limited use and in almost all cases simply using 1 larger motor and 1 wheel drive performs much better than 2 motors and 2 wheel drive. That might sound counter intuitive, but a bicycle is very rarely in a situation where it can't get enough traction to move. In those situations, having the front tire start top slip is a total disaster. Once the front tire loses traction, you lose all ability to balance the bike and will be on the ground at 9.81 m/s2
Unlike a car where all wheel drive is good and you sometimes need it to keep traction, on a bike, if you don't have enough traction from the rear wheel, you just upgrade the tire. If you encounter something where traction is impossible, like a Slip-n-Slide covered in dish soap and bovine birthing lube, try going around it.
