Run that with 52.8V LIFEPO4 today. Last time I will buy a switch from the auto parts store. Was rated for 35 amps and hooked to 30 amp controller. It was a very faulty switch and was a mile away at a coinvent store and had no rear hub to rely on. No pedal chain and a slight hill to go up.
I was easy on the throttle for the front chain and it stayed on the sprockets all the way home. About a mile. I made it tighter after the first run when it almost came off last month.
It worked ok back then when assisting the rear hub , but almost came off trying it at a dead stop solo. Not this time. It stayed nice and tight and got me home.
I took a good DC breaker off an e bike I was not using and tested it for about 2 miles. The front chain works much better now. It saved me from pushing at least 1/2 mile.
That is worth keeping it on as far as I am concerned.
The biggest problem I have with it is that it is the most heavy e bike I have. The front chain motor makes it way too heavy with a battery in the front basket.. If I run LTO it is even heavier but 22 pounds in the rear basket instead of 10 pounds in front.. Then the front can haul 10 or 15 pounds of cargo if needed.
Basically it is like wrestling a bear to push it up like 3 or 4 steps and a runaway train going down them.. It is kind of like a motor cycle more than an e bike..
The little 20" is easier with steps as better leverage with no front motor and smaller bike. Lower center of gravity. riding heavy batteries. The best way to ride it is remove batteries before dealing with any steps > 1 or 2.
12/11/2023. 11:16 AM.
yea. I moved the 6S - LIFEPO4 battery to the rear basket. That will help a little when moving the bike. The two 5S - LIFEPO4 packs are on either side where the 6S - LTOs could go. I can run the 10S - LTO in the rear too so now set up for both 55V -LTO and 16S - LIFEPO4. I charged with my 54.6V - 15 amp charger and got them up to around 90% quickly.
54.6V / 16 = 3.4125V. I will need a 58.8V charger to charge 22S - 55V - LTO. 58.8V / 22 = 2.67V..
I am waiting on my 2,000W black Friday hub motor kit for $138 :44 cents. It was about 20 miles away about 4 hours ago so the door bell should ring any time. I put a note up to ring it.
Wish I could take pictures but already lost my new phone I got last month.
12 ; 01. I will have pictures un boxing. Google found my phone. I will have it later today.
12: 29 PM.
Christmas morning just happened early. I opened the end of the box and the motor is in there. The black controller has a sticker on the front. 48 to 72V and 45 amps.
Looking at a rack on the top but will be able to see the Giant and Roam sticker. I will drill two small holes for 1/4" grade 8 bolts and some pipe clamps on the bottom securing the rack to the top bar. It will just clear the seat and not cover the Roam sticker.
Weight will be about 23 pounds for 16S - 8P - 128 cells at 86 grams each.
128 * 86 = 11,008 grams to pounds is 24 pounds. About 25 with the box. That is 1/2 the weight of 55V - LTO.
I could build a 20S or 22S 66V to 72.6V pack but would then hit 30 or 35 pounds.. I would also have to buy a big expensive charger.
The Giant in the picture below has a 700c rim now. The hub motor is still in the box. I am taking my sweet time with this build and the battery rack and pack will be as small and low profile as possible. There will be no front basket.
I will use a milk crate on the rear rack for cargo but will be removable with wing nuts.. I will only use it when I need to haul cargo. I am looking for a clean professional build. . It is geared for 43 mph @ 52V - 16S - LIFEPO4. It will hit 50 mph @ 72.6V.
If I really want to go that fast I could just hook up my 6S pack in the rear basket is series with the 16S for 22S - 8P - 72.6V and charge it separately from the 16S pack with one of my 6S - LiPo chargers..
I am not sure how I will balance the 16S pack. Since it is going to take awhile to build the battery I might just order a 16S - 50 or 60 amp Bluetooth BMS next month in January.
Thanks.
Skyler.
12: 29 PM.
Thanks.
Skyler.
