Jan-Erik-86
Established
- Joined
- Jan 23, 2019
- Messages
- 110
Hi guys,
My bike is a 26" with a 1000W DD hub motor. Specs unknown, but top speed with wheel off the ground and fully charged 48V/13s battery is around 60 km/h.
I originally had a 26A KT square wave controller that i shunt modded to give around 36A, and at the same time i added some additional 1.5mm2 phase wires to the stock 0.75mm2 wires. This worked perfectly fine for a few months until i got my hands on a 36A KT sine wave controller, and did a swap to get a more smooth and silent ride.
The power felt about the same with the new controller and it worked fine, but as i now only had the 3x 1.5mm2 phase wires, and noticed they were getting hot, i decided to replace them with 3x 4mm2 wires, that could also be significantly shorter due to a new location of the controller - but this is where things that confused me started to happen...
Instantly on the first test ride with the new, and shorter 4mm2 wires, i felt significantly more vibrations in the bike when accelerating from low speed. I thought it could just be my imagining, or that the upgraded wires had less loss, causing more motor power, which again naturally caused more vibrations. But after a day of riding i did notice that the pulling force i once had at low speed have been significantly reduced, but comes back at higher speed.
At around 7-20km/h i see the power is being delivered to the motor, but it feels more like when you choke a petrol engine - you push the gas pedal, fuel is entering the engine, but power just isn't there - until you get to around 20+ km/h where it starts to return again. I know below 20 km/h is a low-efficiency range for the motor, but it's a speed i often used before to pull me up short, but steep and curved hills. Before i could by in PAS lvl 2 (~350W) up those hills, while now i feel lvl 3 (~600W) is suddenly needed.
Does anyone have any idea where to start troubleshooting this?
