Loydbrawn101@gmail.com
New-ish here
- Joined
- Mar 13, 2021
- Messages
- 38
Hello, I've never posted anything before so pls bare with me. I can't figure out how to match continuous and peak current of battery,controller and motor. I keep reading all the same stuff over and over but just can't quite fully grasp it. I'm upgrading a 60 volt scooter to 72 volts. Il basically just be keeping the frame,I'm replacing the battery,controller and motor. It's a fat tire seated scooter so it's hard to find a rear hub motor that will match the size of dropout and size of tire, it's 235mm dropout( I'm pretty sure) and the tire is 225/ 55-8, thats a 18 inch diameter by 8.5 or 9.5 inches wide. I will confirm all that before I make the final purchase.
I'm thinking about a 72 volt 50 amp hour lithium iron phosphate battery. The manufacturer said the continuous discharge current is 50 amps and max discharge current is 100 amps.
I'd like to go with a good sine wave name brand programmable controller,I was looking at kelly controllers but am open to a different one. I will have it programmed at an electric bike shop near me,so I'd like to have clear instructions for the controller,after some time I will learn how to program it myself but il have them do it the first couple times( to dial it in). I'm looking at a 72 volt controller but I can't figure out which one to get because the discharge current part I don't understand. How would I match that to the battery?
Lastly,matching the motor. I found a 72 volt 2000 watt 60 h hub with tire and rim on amazon. I would rather have something more powerful,like 3000 or 4000watt but the 2000watt is the most powerful hub i could find that will fit the existing dropout and tire size. What does 60 H mean?
I'm 230 lbs and the scooter will be around 130lbs with batteries and motor so there's gonna be around a 400 lb total load. Not too many hills. I'd like to go as fast as possible for as long as possible. Anyway, any info anyone has would be greatly appreciated. There's a Pic of the 60 volt 2000 watt scooter that I'm upgrading and the 72 volt 2000 watt hubmotor that il be replacing the hub motor with. I talked to a battery manufacturer and they can make the 72 volt 50 ah battery to the shape I need. Thanks
