I'm planning on switching the regular lead acid battery in my motorcycle to a LiFePO4 pack to save weight and have a longer lifespan. I would be using 12 A123 cells, 3 packs connected in parallel with 4 batteries in series each, to give me a 13.2v voltage with a capacity of 6.9Ah
My main concerns are:
1)With a little search, it seems that the voltage used to charge a 12v lead-acid battery would be very similar to the one used to charge a 4x3.3v LiFePO4 battery pack, since the charging voltage is 3.6v per cell on the LiFePO4, which would be about 14.4v , and the charging voltage used for a 12v lead-acid battery ranges from 14.2 to 14.5v. I assume that charging wouldn't be an issue, am I wrong?
2)The full charge voltage for the LiFePO4 would be significantly higher compared to the lead-acid battery, 14.4v vs. 12.8v for the lead-acid battery pack. Would the starter motor be ok with this increase in voltage without compromising its lifespan?
