Hey guys, I designed the X-era motor and I'll be working on something for extremely fast small EV's. If you all have any suggestions as to what is necessary for this motor, I would love to hear it. I personally want to design the motor with an integrated blower to keep things cool on really steep hills at lower speeds. The biggest problems occur when the motor is at very high currents and barely spinning (hills, grass, etc). I'm also targeting insane power levels and fairly high motor rpm since that is what I'm passionate about. The motor will be in the 3lb range with continuous power levels of 4-6Kw with peaks of over 12Kw. Again, I haven't designed anything on this motor yet...so now would be the time to pile on what you want this motor to be. Things like shaft size, shaft length, material, bearing type, max OD, max motor length, hall sensors or no, etc. is up in the air at the moment. Also, my target price range is ~$400, so it can't get too fancy
P.S. I'll be targeting the Castle SHV250 control since I love Castle products and it will include data logging, and direct hall interface (on the industrial version)
David B.
