mi7d1
I have a 20a 36-72v clyte controller with a reverse switch. After reading several times about the hub motors having a higher rolling resistance rolling backwards with the controller turned on, I decided to try a little experiment while rolling into my parking spot at work. I flipped the switch into reverse and could feel an increased drag immediately without using the throttle. I also tried the same thing using the throttle and watching my WattsUp meter, but in the short distance I was braking I could get enough information from my meter to help. I would like to know if there is any danger to my motor or controller using it in reverse with or without the throttle while moving forward to assist in electronic braking? I was/am interested in regenerative braking not to re-charge the batteries but as an electric drag brake. My velomobile has two Sturmey-Archer drum brakes on the front wheels and nothing on the rear. It would be nice to be able to use the hub motor as an electronic brake without fear of damaging my motor or motor controller and a bonus would be to be able to use the throttle in reverse to increase the braking. Any advise or comments?
edited for better subject title. Originally posted as "Electric Reverse Brake"
