Using transfer case on EV
vax
Keila, Estonia
Just probing the grounds, has anybody thought of using 4x4 jeep transfer case on Electric car?
Basically 2 gears is all you need, with regular gearbox most conversions use 2. and 4. gear, which is 1:1
Basically most transfer boxes should do the trick. Only front diff output shaft would be in the way.
The other option I thought would be Volvo electrically switched overdrive, connected backwards.
Brilliant idea, I also had a 63 Falcon and a 64 truck that both had 3-speed manuals. As small and compact as a 3-speed could be I suppose, but the 2-speed would be a huge improvement.
