beto_pty
So Im working on a proyect that has nothing to do with eboards and I stumble upon a vaporizer or vapping batteries
These are 25-45c discharge batteries from anywhere from 1800 to 4500 mah capacity.
Several brands
http://www.ebay.com/itm/4x-Purple-EFEST-IMR-18650-HIGH-DRAIN-35A-RECHARGEABLE-Li-MN-Battery-2500mAh-/141591287109?pt=LH_DefaultDomain_0&hash=item20f77f9545
http://www.ebay.com/itm/3x-Efest-IMR-26650-4200MAH-50A-Li-MN-Flat-Top-Batteries-GENUINE-TESTED-/171622847792?pt=LH_DefaultDomain_0&hash=item27f584d530
IM assuming most are knockoffs and much of the info is exagerated however...
Looking at the 4200 mah ones...Im of course not assuming that they are real 35c capable however at 4c capable they are interesting... a 24 cell pack of 4200 mah (at 6s4p) could power one for a good 24 km.. and swapping them would be easy as they would be heatshrunk into 6 packs of 4 in parallel so balancing charging could be simplified... Definitly not dirt cheap and probably not light but would allow me to stop dragging 3 boards around so i can ride for an hour and a half...
Disclaimer: I did a search under vapping and efest and found no information regarding these...
Several brands
