I can't imagine wanting to use a cell that gets hot under the load I'd be putting on it every day in a battery pack.
If a cell generates that kind of heat on it's own, standalone, how hot would it get inside a pack?
I know some cells are probably spec'd to operate at higher environmental temperatures, but if they're actually generating those temperatures themselves, and they are in the middle of a pack, the heat of that pack inside is going to increase significantly beyond what one cell's heat is, because all those watts of waste heat are being confined inside the core of the pack--only the outer layer of cells have much surface area to dissipate the heat they themselves generate, and in addition to try to get rid of the heat they're absorbing from the pack's core. Only the ends of the cells in anything but the outer layer can radiate heat out of the pack directly.
How much of a problem any of this is, I don't know.
But heat is in general bad for batteries, accelerating aging and such, aside from the possibility of thermal runaway if core cells cant' shed enough heat and loading keeps making more.
