Nothing visible like that on the one side of the one PCB your picture shows. Is "VEC500" one of the VESC projects? If so, have you checked the schematic from that project to see what fuses, if any, are in the circuits? If not, have you checked the other side of the visible PCB, and both sides of the PCB(s) under it?
Do you have the correct voltage supply to the controller, and the correct signals / etc to it to command it to turn on?
What led you to start testing it? Meaning, was it working and then stopped working? If so, what happened to it between the time it worked and the time it stopped working? These may lead to troubleshooting steps.
