carpoolscootah
🧲 New user
So I am personalizing a Cosmo I have added a brain power motor controller 48 volt and a zp-883 trigger eye display upon initial setup I just plugged things in to make Shure it would work, throttle was working great all three years proved to be an increase in miles per hour but nothing was in place , so after getting everything in it's location I needed to run my throttle wire through the little hole in the front end and I having to do that I needed to unpin the five pin throttle plug and didn't take a picture of which color pins went in what spot in the connector (the wire colors dont match on controller side plug) having a hell of a time trying to f****** figure out where they're supposed to go cuz now I'm reading that I got to air E6 code so either be a low voltage (im using a 36v battery on a 48v controller) or it's a communication error in my f****** throttle hookup and I can't figure out the correct pin out for the speed controller can somebody please help me
48v Brain power motor controller
zp-883 (tf-100 generic triger display)
