nate0m
New here
I've been working on making FLIPSKY 75100 work for my ebike. My main issue is the brake sensors. I was using 2 pin brake senors hooked up to adc2 while using the 'current reverse current brake button adc2' option in the input wizard. But I thought, and I might be completely wrong here, that if I got 3 pin brake sensors that then I could use the brake sensor like a second throttle so that I would have more control over the amount regen braking. With the 2 pin brake sensors regen is either 0% or 100% depending on if you press the brake or not, and this is not ideal because it makes the braking very jerky. So I got the 3 pin brake senors and wired them up to gnd, 3.3v, and adc2, but when I went to do the input wizard in the vesc app I don't have the option 'current reverse current adc2'. I've had this option before on one of the Bluetooth models of the FLIPSKY 75100 and I was using the android app. But his one is not Bluetooth so I am using the Linux app.
Is this a viable setup for better regen on vesc?
How come I could hook up 2 throttles to the Bluetooth version on the android app, but not on the non Bluetooth version on the Linux app?
