Dui ni shuo de dui
Great build, lots of very nice work!
I absolutely love the paint booth idea, it's brilliant. I'll buy one right away!
Dui said:Great build, lots of very nice work!
JimVonBaden said:I added another internal crossbrace, drilled and plug welded, plus perimeter welded. Then I boxed in both ends. It weighs 28 pounds. If this isn't strong enough, nothing is.
Dui said:JimVonBaden said:I added another internal crossbrace, drilled and plug welded, plus perimeter welded. Then I boxed in both ends. It weighs 28 pounds. If this isn't strong enough, nothing is.
whuuut?![]()
Are you sure it's right? That would mean that your swingarm is heavier than the entire frame of my motorbike?!?
That sounds crazy.
mannydantyla said:I'm going to need one of those for my garage too (except I'm getting to ready to demolish it and build a new one, I just sent my plans to the city a few minutes ago)
Dui said:My suggestion if I may: do not cheap out on the plugs/connectors quality. That makes all the difference between a reliable setup and an unreliable one.
Try using only waterproof connectors, and if possible weld the wires. Takes longer, cost a little bit more, but that saves so much time and money later...
That's what I'f done on my last motorbike, litterally never had a single issue with it in three years, despite riding under any kind of weather.
