Votol EM 100 throttle doubts.
raf120
Filippo1_
Hi all, I have some doubts with my new votol EM100....the throttle is not responding correctly....it goes from zero to maximum speed, it is not modular. The throttle voltage set are correct, don't know if is because I'm playing with the motor on the table without any load.
Thanks for give me an answer.
Mi piace
Commenta
Invia
If it's current (torque) control throttle mode (or controller type, like with FOC controllers), then throttle doesn't control motor speed, it controls current to the motor. Offground the motor only takes a small amount of current to reach full speed.
In such a situation, riding it on ground would then work as expected (assuming the rest of the controller is wired and setup correctly for your system).
