Watts Up Mount
Just received a Watts Up meter in the mail and am wondering about mounting options. It has no holes or other obvious mounting points. Connections to the wiring look to be very straightforward. If anyone has mounted one of these to a bike and could describe what you did, I would appreciate it. (Pics would be super!)
Thanks,
Eric
My solution is thick double sided tape on the bottom of the case and zip ties arround the wires near the case. It sits there nicely and doesn't rattle yet, but I'm not 100% happy with my solution. Nothing more elegant comes to mind...
Ypedal said:
Xyster would use duct-tape... :wink:
Yah, over your mouth! Be glad, Ypedal, my ebike's range is a little better.... Just Keeding, Just Keeding :D
I don't know what the back of the device looks like, but I'd probably first try super-gluing to the reverse side a couple of those plastic clamps used for attaching accessories, like bike mirrors, to the handlebars.
The case is all plastic and the back is flat so super glue to handbar clamp sounds like a great idea.
this is how I monted mine.
First I fited it into small box by Hammond Mfg. sold here by Active Electronics. Found ideal size with enough room for AWG10 wires soldered to WatssUp wires.
Box is poistioned up side down.
I cut out openning in the bottom of the box just enough for LED screen
Box with WatssUp in it is positioned up side up with lid screwed to alu bracket which in turn is screwed to the bicycle stem central screw.Hope it helps.
You can drill for screws in the box , you cannot drill and tap unit itself.
MC
Since I'm absolutely lousy at posting photos and since I don't have a photo already and since my bike is in the garage and I'm not, there will be no photo.
The handlebar on my Jamis cruiser came with a foam type wrap over the handlebars when I bought it 12+ years ago. I've had to cut sections out to mount various stuff but it came in handy when I mounted the Watts Up meter. Lacking that I would definitely provide something on the handlebar to provide a little shock resistant assistance to the meter. Two zip ties, small ones, one on either end have done a admirable job. Should I need to remove it for any reason all it will take is two little snips. A dab of silicon caulk on either end where the wires come out makes it as waterproof as possible.
A double wrap of an old innertube would be an ideal surface to mount it on. Lacking that a piece of foam sponge. I've long since give up on giving my handlebars a neat appearance. There are two brake levers, throttle, cruise control, computer #1, a horn, a Sony bike radio including computer# 2, holders for the front basket, a mirror and the Watts Up meter. The other horn is mounted below the handlebars. (gentle horn for pedestrians and loud horn for vehicles and other bicycles that don't hear my radio and get out of the way)
So far the Watts Up meter has provided a level of confidence in determining range which makes a long trip much more pleasant. By averaging around 15 MPH I know I can make it twenty miles as I can see that I'm getting almost three miles per AH and I also get an accurate WH count and a constant state of voltage remaining in the batteries. Monday morning I had a very pleasant 15 miles ride averaging 18 MPH and while I forget how many AH and WH I used it was well within a comfort zone. The batteries were still reading 46 volts at rest.
If you have any problems wiring it PM Liberator or ask me and I'll tell you how I did it.
Mike
I'm planning on designing an aluminum handlebar mount for my watts up meter and milling it out later on this week. If you'd like I could post the CAD file or an e-drawing.
At the cyclone-usa sight the sell a handlebar mount for the Watt's Up. There's no pic so I have no idea what you get for your $20.
http://www.cyclone-usa.com/store.php?crn=202
(scroll down to the 4th section.)
