I have had an interest in gas motorized bicycles for several years and put together a few bikes, some good, some not so good.
I intend to swing from gas into electric bikes but need to learn more than a few things. I am also on the motoredBikes.com forum which I think very highly of. Already have received some good help from a couple members on that forum about the electric approach. This forum was recommemded and after reading some of the posting for the last couple of weeks I can see why. There are some pretty sharp people here. Much of what I read seems to go right over my head, but just joined the forum thinking that if I get a little involved some may sink in.
Here is where I plan to start: Using a terra recumbent trike using bike chain and gears as the electric drive train and having the ability to shift into low or high range gears. I used this same system on a Tour Easy recumbent powered by a 1.6 hp Subaru motor and it works very well. In low gear it will climb a telephone pole. I am interested in a top speed of 20-25 mph, maybe even 30 mph but that maybe asking a little much. I need to go for some good range (25-30 miles???) and at the same keep the weight down.
All the above is intended to give a little back ground and briefly explain what I'm trying to do. So, here comes my first question: Watts, If I use a 36v high watt motor, say a 1000w motor as opposed to a 36v 500w motor. I think I read somewhere that it does bad things to a 1000w at slow speeds, 7-10 mph. With the ability to shift gears and speed of around 20 mph with a top of 25-30 mph, 1000 watts maybe an over kill anyway?????.
I will be interested in what your thoughts are.
Best Regards
Bill Snow
Best Regards
Bill Snow
