agniusm
So after my misfortune with Chinese A123 seller i have started digging to see what else i could use easy acquireble on todays market without spending too much money. Someone here back home was testing CALB and thundersky batteries and the news were pleasing. Dont know the details, what i know that CALB 100ah cells were used 13kW of total capacity: http://www.emobilis.lt/. He was using the car daily for one and half years and the capacity have not changed.
Now i came across this manufacturer Elite Power Solutions (http://elitepowersolutions.com/products/product_info.php?cPath=25&products_id=145). They have distributors all over US and one in Germany. They supply all the bits and pieces plus warrant their products. Most important thing is they produce 20AH cells which is exactly what i need. Sure they will be 6kg heavier than A123 but considering that individual cells have some sort of plastic casing and terminals it comes close to A123 prismatic cells and the fact that a123 cells are very complicated to acquire plus the sky high price makes them unattractive, never mind high discharge currents, i am not planing to beat speed record.
Here is my question. I am developing a full suspension cargo bike with 6061 alloy in mind. I will be using HS3540 clyte hub motor at 72V. So 24 20AH cells @ ~16kg. So basically by the info i found HS3540 can run @ 2kW comfortably and peak out at 5kW. So doing the math the draw @ 2kW when cells are charged to 3.65V would be ~23A and peaking out @ 5kW ~57A. The cells are rated @ 2C discharge and thats 40AMPS, and 10C for 20sec which is 100AMPS, so i fit in the brackets with some reserve. Please do correct me if i am missing the point here. It is very important to me to source the right cells to design my frame without redoing it. If i would get those cells i would go for their 10AMP charger cause it looks kind a solid: url]http://elitepowersolutions.com/products/product_info.php?cPath=9&products_id=205[/url]
Some pics:
Thank you
Some pics:
Thank you
