What Charger to Get
higrade
Ok i only need two more items to start mockup, my WII remote and a battery charger i have 2 3s 5000 plan to get 2 more down the line what affordable charger should i pick up. Best price, just want to get the job done to charge all 4 batteries. overnight charge is ok
I wouldn't bother with overnight charging. It's most of the time safe but I wouldn't bother risking it.
I would prefer a quicker charge that can charge in 20-45 minutes and you can disconnect everything afterwards and not worry.
iCharger 208B is by far the best charger. Can charge up to 20amps and only about $130.
HobbyKing 350W is about $41.99
HobbyKing 540W is about $67.99
I bought a ton of the Imax and Accel chargers which charge at 5amps which are really slow $40-50 bucks. Spend the money get the better chargers.
I usually charge 2 to 6 packs in parallel at 10 to 15 amps.
If your using 6S and 6 packs the 540W power supply is better. Otherwise 350W works great.
Professionnal hijacking again !! 8) Just kidding :lol:
Can this charger do the job for 10S6p (15000mAh) ? LiPos take better fast charge than Li-Ions I think, and I use Samsung 25R?
You'll need the 10S capable iCharger. 3010b I think but it might only be up to 10amps. Not too sure on the Samsung 25R charging rate.
