hi,
long time e-bike wannabe, taking the plunge to get some parts together and assemble a bike.
What do you guys think of these kits from ebay?
48V 20Ah, AU$387 [cheap nasty? is the charger going to damage the batteries?]
http://www.ebay.com.au/itm/2013-48v-20ah-LiFePO4-Battery-5A-Charger-BMS-For-Ebike-Powerful-Sea-7-8-Weeks-/130923064982?pt=AU_Electronics_Batteries_Chargers&hash=item1e7b9f6e96&_uhb=1
48V 1000W rear wheel [cheap nasty? - will the controller prevent over discharging the battery?]
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=111198095220&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
I've previously read of the problems with high power wheels transferring power to the bicycle frame safely. Recall seeing some kits that include brace arm brackets for more secure mounting of the wheel to the frame.
I've seen various battery problems in different forums, overdischarging cells within battery packs seems to be the main cause of premature battery pack failure. I suspect the cheaper battery chargers will not have the features to prevent over charging (either over voltage or overcurrent) and the cheaper battery packs may not have features to prevent over discharging individual cells. [do the better battery packs have features to prevent over discharging individual cells?]
finally : is there really much difference between the amp.hour discharge rate cycle between LiFePO4 batteries?
