What fork do you use and what's best?
rui_fujino
UK/Japan
Hi, I've been riding ebike for good 2 years and built 4 ebikes. Through out the whole building, I've always wondered "what's best for rider and the bike".
So, I would like to know what you guys think of best front suspension fork experiences with specific setups are!
I think for full suspension, additional rear suspension advice might be helpful too!
so far i had :
Rockshox Dart 3 (2006 model) 100mm travel on my 26" HS3540
Upgrading to Fox 32 Talas (2010) 100,120,140mm travel soon... :!:
My favorites, among the long travel DH forks :
Boxxer WC Solo Air... Lightest of all pro DH forks, very wide tuning range, very quick setting, high maintenance.
Boxxer WC Ti... Very light weight spring pro DH fork, wide tuning range, very quick setting, very low maintenance.
Fox 40... Light weight spring pro DH fork, wide tuning range, very fine tuning precision, low maintenance.
These suspension forks cost fortune and I have been hunting on craiglist and ebay.
Rockshox Tora 120 or 140mm, I bought for 100 bucks (140mm) and I rebuilt by using Rockshox rebuild kit for less cost. Very worth! I would suggest if you are looking for Rockshox and MAKE SURE find the fork comes with "Motion Control" feature. They rocks and very plushy better than my old Rockshox with Pre-Loaded springs.
There is no one "best", as it depends on too many factors to narrow down very much. ;)
Even saying whether suspended or unsuspended is better, depends on the design of the rest of the bike, rider's needs, terrain, weight limitations, etc.
That said, what I'd use if I could would probably be a modified moped or motorcycle front fork, simply because of the loads I need to carry and the bad road conditions around here (where "construction" doesn't ever stop, and is rather more like they just want to spend money digging things up and patching them over and over, rather than doing things right the first time and having a road that will last 20-30 years or more, instead of "fixing" things every few months (or leaving them unfixed for years, which is more common)).
I'd also probably use a motorcycle rear shock, for the same reasons.
I'm sure they make bicycle stuff that can do what I need it to and weighs notably less than the MC stuff, but it also probably costs more than a small car or nice motorcycle--meanign I could buy a whole motorcycle and salvage it for all of the parts I'd need for my "ultimate cargo bike" build cheaper than just getting a single bicycle-type fork. :lol:
The "nicest" fork I've ever had is an old (2005?) Manitou Skareb air/oil fork, which leaks air and has to be repressurised every other ride (several times a ride if I am carrying a load on the front). But it was old when I got it, already in this condition. New, I'm sure it was better. I still like it better than the other forks I've got but it won't do the work I need it to, mostly. The oil damping needs work, as it has some bob to it, regardless of adjustments--probably bad seals somewhere inside--but it was probably nice when it was new.
The nicest reliable fork I've ever had is a Suntour low-end spring/elastomer I forget the model of, but I have two--one from a bike shop junk shelf and one from Mdd0127. Does way better than any other similar fork I've had, including the pretty similar RST omni that came on DayGlo Avenger (probably from 2005, as that's when the bike was made). But it isn't adjustable and isn't designed to handle what I put it thru with CrazyBike2, so Ic an still easily bottom it out especially going straight into a driveway or parking lot entrance--I ahve to enter those at diagonals even at low speeds (<10mph), or BAM! :(
Beyond that, all the other suspension forks I've had are crappy.
Non-suspension forks; well, I have a few bikes with very similar ones, typically the "OTS" curved types. These are nice cuz they're lightweight and strong--never broken one so far. They do ok for what they are, but I can't use them with my heavy cargo bikes without risk of destroying the wheel that's on them (have broken wheels using unsuspended bikes for heavy stuff on our roads here). I also have another similar but even stronger one that LI-ghtcycle sent me, by Trek, I think, but it is a good strong one I could probably use on a cargo bike at lower speeds (<10mph) or on nicer roads, for instance if I stay in the left side of the righthand lanes, not going rightward of the center of that lane on most roads.
The ones 'veI used, in order of preference:
commuting
1 - Fox 32 RLC 100 with compression ~halfway
2 - Marzocchi Bomber, custom tuned
3 - RS Psylo
longer travel off-road fun bike
1 - Marzocchi 888 RC Ti - simply stunning!!
2 - Fox 36
3 - 2007 Marzocchi 66, spring in left leg only
4 - Marzocchi Jr T
You will be very happy with the Fox, just look after it.
If money is no object the best suspension is arguably made by Bos. Although DVO look promising.
My experience is quite limited. But I've been very happy with both front and rear shocks that are air tunable, vs cheaper stuff with just a preload screw. I like the abiliity to set em up very hard for street conditions.
The main thing is getting out of cheap crap like zoom or spinner. You figured that out obviously, but others reading haven't yet.
I have mazocchi bomber 888's and they are excellent. But I have the same amount of travel on the rear. Fox rc4 240mm's of travel.The main thing is the travel you have on the front you need on the rear. It all depends on the frame and if its built for 125mls of travel and u have 200 on the front it won't be safe. :D
I think you'll really the Fox, the dart is decent, any of the big brands make good and decent forks, anything resembling a wallbike or bso might actually be better without suspension. My first fork was an sr duo track, it weighed a ton and had about an inch of travel, it would clunk on every big bump because it bottomed out, little ones couldn't overcome the stiction! Finally it seized up so I went to a chromoly fork. Big improvement! Later I bought a cannondale super V with an 80mm head shock, ironically for the head shock. It was nice when it worked, but that was only about a week at a time! One time I rode up one of the mountains in Colorado and it was flat by the time I got to the top, it did have a lockout so I extended it out and locked it. I was racing at that period in time, spent more time on a hard tail rental than my bike! They finally gave me a moto freeride as a warranty, its like two leftys! I still have it, not in use, with a tuneup it would be a great ebike fork, 100mm and very stiff! I switched it out for a Manitou Sherman m1 150mm, with 20mm thru axle, not necessarily an upgrade, other then more travel (I modified my frame to have 6 inches instead of 4). I've also spent time recently on a manitou Nixon, feels decent, but has noticeable flex. I also have an older boxxer, 200 mm its insane, you can ram curbs flat out and it soaks them up! They'll go on my ebike. I've test rode quite a few through the years and I liked the Marzocchi, and now the Fox. I think proper setup for the use is as important as the brand.
