Thank you for your input so far guys. I have been looking at different options and I have the numbers for one of the easier options. That is using three Turnigy 80-100 outrunners re winded with 7 turn delta, giving me a Kv of 151. With 50v and a load reduction of 0.8 that I have found to be realistic I get a loaded RPM of 6040. (50v x 0.8 x 151KV). I have been using the numbers from http://www.jobymotors.com/public/views/pages/jm1s.php to verify the thrust calculator from http://personal.osi.hu/fuzesisz/strc_eng/ and found them to correlate relatively good when using a CF of 1.25. Looking at the pictures I will get around 25kg of static thrust @ 6Kw input per motor with a 26" x 10" propeller. Three of them will give me 75kg static thrust and more in flight. That should be plenty for quick launch and climbing. That is only 18Kw from three motors, far from the 25Kw I initially aimed for, but it is the thrust numbers that is important. This require 120A per motor, something I think they handle with plenty of cooling for short spurts.
