ryan
My setup currently looks like the following diagram, but I'm having a few problems.
1) Small Powerpoles come loose
While the larger gray Anderson Powerpoles are fantastic, the smaller ones are unclipped really easily. I've resorted to using zip ties to hold them together -- one small loop on each wire behind the powerpole, and one larger one linking the loops to hold them tight. But this makes it semi-permanent and any debugging requires clipping and relooping the zip ties. What else do you recommend? I've also considered putting larger, stronger red & black powerpoles (SB50) on each terminal and ignoring the +/- on them and wiring for charging and as a series. What do you think?
2) What's the Yellow Wire for? (CH-)
My Headway packs came with a yellow wire out of the negative terminal marked "CH-". Any idea what that's for? I just left them taped off.
3) Any other recommendations?
This is my first build and I could use any other advice you have.
