Where can I find a pinout of the eb306 Keywin boards?
HypnoToad
South west uk
I'm almost done building one of these boards up with my own fets but I'm struggling to find info about this board online
Most threads relate to programming or changing LVC resistors.
On the PCB there are many connections, TA, TB, SP, SLA, P1, P2, etc.
What do these all mean?
where do I connect my throttle wires?
Here's a pic which should help, I think I've already soldered the hall wires in the right place.
Thanks
i am not sure which one, but at least one of the modification threads has complete info though the pads might be moved the names are the same or closee nough. could take some reading of the many threads to find; it's a post with pics and has lists of which pads are what, probably by knuckles. afaicr some of the words and names in the post have corrupted characters between other characters that are correct, so you might have to do some pondering to figure out what the actual pa d names listed are compared to yours. :(
should be in one of te links from here
http://www.endless-sphere.com/w/index.php/EBike_Controllers
or here
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=19446
like
http://endless-sphere.com/forums/viewtopic.php?f=2&t=8610
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=10312
this document from the thread above
http://www.endless-sphere.com/forums/download/file.php?id=80022
haven't checked but maybe even
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=9191
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=14798
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=5713
http://endless-sphere.com/forums/viewtopic.php?f=2&t=8317
http://endless-sphere.com/forums/viewtopic.php?f=16&t=7361
totally diff controller but some pad names seem the same so far as i know
http://www.endless-sphere.com/forums/viewtopic.php?p=670674#p670674
Thanks for the links, I found by the process of elimination that it seems to be the SP pin that is for the throttle connection:
By the looks of it only the bare minimum is hooked up in this pic, so I'm going to try hooking up the SP pins to the throttle and hope for the best.
Once I have the throttle going I'll then worry about the other stuff such as tweaking the settings. :)
very nice links collection !
have fun!
