OK looks like the 8mm is a Lenovo "standard" laptop tip, identical to both the Yeti and Sherpa input plug.
Not a common tip size until Lenovo switched to 20V with their laptops requiring 90W power supplies.
Most vendors list the precise spec as 7.9mm OD, 5.5mm ID with positive center pin (positive for Lenovo, TBD for Yeti.?)
but apparently some of the universal tip vendors go down to 7.7mm OD, which presumably works OK.
Some detailed discussion here: https://forum.thinkpads.com//viewtopic.php?t=57469
This shows precise measurements
http://www.bixmart.com/LC80--Right-Angle-Connector-Converter-for-IBM-Lenovo-Laptop-Power-Adapters-_p_197.html
Sources
http://m.ebay.com/itm/DC-Power-Tip-Plug-Connector-with-Cord-Cable-For-IBM-Lenovo-7-9-5-5mm-/262776227220
http://www.bixnet.com/dccotipforib.html
