Farfle said:
Not quite so sure about cost. lesser cell count , lower charger/bms cost and easier balancing as there is more cells to "average things out". no way a 30s 4115 setup will be more efficient as a whole, (weight and space efficient) than a 4110 setup.
Don't forget the biggie, the high turn count motors and high voltage controllers are much more prone to failure, making the real world cost drastically higher. On the motor side, that's a big part of why they aren't being sold anymore....well that and such a small minority want slower and lower power, the true end result of these
systems. The Chinese are smart enough not to go the high turn count motor route. Instead they use less motor for slow and low power. The little 15kph restricted emoped that I got for free has the same kind of motor, but with only a 19mm thick stator, so less weight, less copper, less magnet, so definitely lower cost.
Somehow the selling point now is a miniscule amount of additional losses in the wiring. Justin tested the 7 turn 9C and came up with 70A as saturation. That's phase amps, so what would it be for a 12 turn? Is it directly proportional and 41A? Who runs phase currents that low? That's where the high turn count house of cards falls down, and even explains why Dogman melts one a year.
While I'm on the topic of busting myths, this latest one that showed up on the forum this year is the term "9C clone". You've got to be kidding. No one clones a 9C. It would be like a Tata clone. Just because different motor winding shops buy some parts made in the same factory doesn't make one a clone.
