Which BMS for Headway?
dingoEsride
Perth, Australia
I"ve come to the conclusion my 16s 38120 headway BMS is kapot after it drained cells and then after balancing was re-connected and when reading total volts at 55 would not turn motor when a similar battery pack does,
so should I go with
this..
http://www.evassemble.com/index.php?main_page=product_info&cPath=6&products_id=211
which is the same as the not very old fizzled one
or this...
http://www.ebay.com.au/itm/221172143478?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
another option is $40 cheaper and similar to my robust older headway pack,
any advise is appreciated,
mark
I like this BMS because it has LEDs showing when each cell is in balance mode and I have had no problems for several years.
https://www.aliexpress.com/store/product/16S-Lithium-LiPo-Li-ion-Batteries-Protection-Board-BMS-System-48V-58-4V-50A-Continuous-Discharge/313864_2048436065.html?spm=2114.12010612.0.0.gPvDE7
The price is right too. :D
Oh Yeah Zip, the battery is fine, all cells rock steady and balanced and will run the motor no probs, but it's a pain to charge just a 4 or 6 group at a time with the bc 168 charger unless there's another way
