DogDipstick
serious_sam said:100% agree.
Minimising stress in the axle is the goal. Minimise stress by maximising the area over which the force is applied => tight fit and maximum surface contact.
You spelled minimize and maximize wrong, friend, but I know you are not native to England so I will give you a break.
I hear your theory: but:
I thought minimizing stress in the tork plate is the goal... so it does not fail? What are we taking about here? An axle break or a hub spinout? Which one is more likely to happen ( on a DD hub motor, on a bicycle, or a geared motor, on a bicycle....)?
I thought it was the latter. I would be mistaken; if we worry about our geared hum botors doin a spinout; but they actually break the axles? Wow did not know that. I thought only a few QS motors and MXUS motors were the ones to break axles. Did not know you had to worry about a broken ax on a geard hub.
You learn something every day.
I care cause I am doing something of the like right now. I was told steel, hardened, tool, over aluminum, the dimensions to make it work, and the forces involved by someone certified and licensed ad insured to give such info.
