Just found the specs on the 380. Looks like they only put out about half of what the 540 does. Maybe I'll try to put the 540s on that mount. I'll have to drill and tap new holes for mounting the motors since the spacing is different. I'll also have to make the holes on the motor gears a bit bigger since the 540 has a bigger shaft. I hope there is enough spacing between the two motors to even fit twin 540s. You would need a little over 1/8" to make it work.
Of course I'm assuming those little gears can even handle what I'm about to try with them. I may have a few Mabuchi motors for sale shortly (at least they're cheap).
