spinningmagnets
100 TW
Any window that is made so that half of it can open will have to be able to slide up and down (or side to side). This means it has to be loose enough to be able to slide, and even thoiugh the gap doesnt look big, when there is a pressure difference between the inside and outside of the house, there will be leakage flow.
I moved to Kansas a few years ago, and the house that was the best deal for us had standard single-pane windows where half of the window was separate and could open. The house has a basement and because "cold sinks", the basement is always 10-degrees cooler in the summer, compared to the rest of the house. We made the basement a den of sorts, but whether we were heating or cooling, the temp of the glass showed we were losing money.
We bought what has been advertised as "storm windows". It is one large piece of glass, with thin rubber seals on the side that presses up against the stock widows' framework. Of course, depending on the style of the home framework around the windows, this solution might be difficult to mount properly. Fortunately, mine were easy.
Even without waiting for the next months A/C bill, I could tell the A/C was not coming on as often, and the bill revealed a big savings with a quick ROI. Not only that, but it made the outside noise from the neighbor-kids much quieter.
I also remain a firm believer in shading the outside of a window, and also the sunniest outer wall. Even with wall insulation, having shade on the outer wall is a big help, and cheap to do.
