Window AC converted to remote package unit (central ac) see page 9
Chalo said:
The bum who lives in my shed used a space heater last week to quadruple my electricity bill compared to the previous week.
Sounds like the shed might need some insulation and possibly sealing up air leaks.... ;)
(I've recycled styrofoam shipping coolers and other foam shipping insulation to do this with reasonable effectiveness--not as good as purpose-made stuff, but it helps a lot).
Chalo said:
Matt Gruber said:
EM
a radiant space heater is often far better than central. you get that toasty warm spot in a minute :bigthumb:
The bum who lives in my shed used a space heater last week to quadruple my electricity bill compared to the previous week. So yes, sometimes localized heat is what you want, but resistive electric heat is woefully inefficient.
For a bum i'd use an electric blanket. toasty warm and only 120 watts :bigthumb:
I'm using one and i don't think anything can beat it. :bigthumb:
Hi Matt,
This is a long thread started in 2017 with so many posts. Can you give a summary of how you install conventional window AC units to make it quiet and still efficient? Ideally with some pics or diagrams. I may want to do the same to 2 adjacent second story bed rooms in our house in NYC. Our 2 small window AC units are not permanently installed (double hung windows) and are removed after summer is over. They cool the rooms fine but is too noisy for a good nights sleep.
There are several things I have used for significant noise reduction on a room used for home studio audio recording, enough to be able to leave it running while recording louder audio sources and still get a usably clean recording. These all assume a unit with intake on the lower portion of the front panel, and output on the top portion of the front panel, and controls on the side of the front panel. If yours is different, you will have to adapt them to yours.
It's a lot of work, and not worth it for most people.
Remove the front panel of the AC unit. If there is intake filtration in this part of it, you may need to cut away this portion so it can be left on the unit to keep the filtration (you need this), but move the filtration to the intake part of the duct you will build in a step below.
Cut part of the top of the AC unit away, starting from the edge that meets the front panel, back to the back wall of the unit's squirrel-cage circulation fan box. This is so the SC fan can move more air more freely, with less turbulence and thus less noise.
If there is a grate or other protective wire cover over the rear exhaust fins (the ones on the outside that get hot during operation), you can unbolt it from there and move it away from the fins to decrease the exhaust fan noise.
If you can protect the interior of the unit from rain and other intrusions in another way farther from the unit's casing, you can cut away the intake grilles for this external fan, and that will also reduce noise. (if you don't have anything there to keep thigns out, birds or other animals may nest in it when not running and get killed when the fan turns on; they may also damage the wiring/etc).
Mount the window unit on a standalone frame not attached to the house, but instead rising from the ground. If you have to mount it to the house, then you'll have to live with the low-frequency vibration it's going to induce into the walls.
The unit only has to be inches away from the house, just not touching it. A foot away from the house gives you clearance to make the duct below, and work with / on the unit if ever needed. If you want more noise reduction from airflow, turn the unit 90 to 180 degrees away from the house so the duct will have to route air in an elbow or U shape, which can significantly decrease fan noise in the airstream.
Then use layers of styrofoam (either sheet insulation or old flat-sided coolers) to make a divided duct attached to the AC unit (permanently using sprayfoam, for instance, or temporarily using other methods). Make the duct not quite touch the house. Line the entire interior of the duct with noise-reducing materials; you can use commercial ones or DIY these (see the many webpages/forums for reducing noise in home recording studios for numerous options). If it is not fairly dry where you live, you will need to cover the outside of the styrofoam with something to keep it dry, or it will absorb water and become mildewed, and likely eventually penetrate into the inside and make you sick. (it is very dry here so I don't have to worry about that).
The AC-end of the duct needs to be tall, with the "wall" that mounts to the top of the AC unit behind the SC fan box cut line angled forward from there at >45 degrees (anything up to vertical 90) so the SC fan air is able to cleanly exit the SC fan box area, and then be redirected into the horizontal duct. If you can make this a curve, even better, but it works as a flat surface if you have to do it that way.
The divided duct will need to have 2/3 of it's volume for the intake, and 1/3 for the output. (you can make it half and half but this may makes more noise, depends on a bunch of factors). It has to be divided or it will only cool the duct, and not the room. The divider needs to extend into the room itself, for at least a foot, so that the cooled air is not pulled right back into the intake. You will probalby need to make vanes on the output side to push the air at an angle away from the intake.
The duct should change size and shape smoothly from the front and top of the AC unit to the window's full opening size and shape. The bigger the window opening, the better, as it will decrease the air speed required and this decreases noise.
Then use a layer of squishy low-density foam (like weatherstripping for doors) to complete the connection to the window. This prevents vibrations of the unit from vibrating the house, which will make a huge difference in low-frequency noise (which you may not perceptibly "hear" but you will notice when it is not there). I recommend doing this to the divider as well, at the point it enters the window, just like the rest of the duct, so that it doesn't pass vibrations into the house via the divider. The internal divider portion will mount to the window itself.
I recommend mounting the intake filtering unit from that front panel you removed from the unit on the intake portion of the above, at the inside of the window. That way you can still clean it as needed. (if you don't use the intake filtering, you'll have to clean the actual unit's intake condenser fins, and that is a PITA job to do; without cleaning them they'll clog up with dust and the unit will stop working).
The control panel that you took off the front of the unit with the rest of it's face will mount on the inside of the window, and you will make an extension cable from it to the unit itself. Depending on the window shape and your duct design, you may be able to simply mount the entire front panel including the intake filtering on the inside of the window.
Exactly how any of these are done will depend on your unit, your house / window, the ground and conditions outside, and your materials availability, DIY skills, budget, etc. You may need other adaptations as well.
If you have direct sunlight on the AC unit, and/or high outside air temperatures, I recommend at least doubling the thickness of the duct walls with the styrofoam insulation, and using more of it to create a shade panel over the top of the whole unit and as much of the sides as you can, that stands away from it far enough to allow good air circulation to and from it's exterior intake and outlet ducts.
If the unit has a noisy compressor or external fan, you may have to insulate the entire non-opening portion of the window against vibration so it does not pass the outside noises on to the room. The simplest way to do this is a large block of thick foam (like many couch cushions or foam mattresses are made of) completely filling the entire window area that is not occupied by the duct/opening, preferably so it contacts all the window glass so the glass can't vibrate.
The point of the modifications is to decrease vibration from the unit to the house, and decrease turbulence in the airstreams both intake and output, on inside and outside, which all reduces noise.
If there is insufficient airflow due to too small / long a duct, you can increase it by installing a "wall" of large-surface-area computer case fans, at least 7-8" diameter, run on 5-7v, instead of their intended 12v, to reduce their speed and noise/vibration. Power each fan at a slightly different voltage, so they are not in sync and don't "thrum" from resonance (or use all different brand/design/RPM fans). Use Nidec or other good quality fans with bearings, not bushings, that are designed for quiet operation. The "wall" of fans needs to fit closely together and right to the edges of the output duct, so no air backflows around them. They need to pull air out of the duct so that then pulls more air into the duct (pushing air rather than pulling will make more noise and works less well).
I did consider the Midea U shaped 8,000 btu last summer but didn't buy one because it was kind of expensive. I bought a used one locally yesterday that's like new (used for 1 month last summer) for $250 cash.
Just need to get it out of the car and install it.
Works great with 1st day in season 6 at 94F :bigthumb:
attic loft up to 106F with window fan ON.
still get 66F from the vents.
glad i sealed the DRoom window. now the breeze does not force in heat.
Enough testing, this is year 7.
I plan to do some upgrades this fall/winter:
1. eliminate the original 1989 long return duct. it is up high and wastes btu's.
2. install new 12k ac. bought it in 2018, might as well hook it up.
3. better condensate drain.
4. better access for service (can't clean the test units).
5. 20x25" Merv 8 filter (got 3 new for free from a neighbor that changed system)
6. paint. got some free paint so might as well make it look nicer (dark grey)
Thanks for reading :cool:
EDIT
this video shows a new house being built w/1 ton per 1000sf. I intend to supply the LR which will be 4 rooms, 1000sf if it works. (will shut off room on super hot days if necessary)
last chance to do some experiments before changing.
I checked the coil temps and the 2017 Haier 5k was 67F and the 2003 Haier 5k was 60f. these 2 are in parallel so they should be the same. maybe the 2017 is not working right. I lowered the fan speed to compensate as the coil was dry and the 2003 was wet.
at 10:30 am the kit. vent is 62F and the return grille is 77, so a 15F Delta.
Hopefully it will remove more humidity while not icing. Been getting 5-8 gallons of water a day :eek: BUT it never goes below 50% RH.
been reading up on ac systems.
EDIT checked the drain, much more water :bigthumb:
Here is a great video of a DIY old school split system for "only" $3300 including necessary tools.
compare to my idea, where you use a big fan to bring in fresh air to the condenser section of a window ac in the attic and duct the condenser exit outside. This could also be done in any spare room on the main floor with a window. Room ducts will go where you decide.
my cost including a spare, and a back up system(not connected to the main system in any way) was $680 and did not require any special tools. and no messing with soldering or charging the freon. (mine are all done at the ac factory)
pic of my AC hall duct. very efficient to get ducts out of the hot attic
Yeah, I wish when they'd rebuilt this place after the fire that they'd left the split-unit A/C on the ground (instead of putting it on the roof as a single unit), and that they'd left the ducts in the cieling/joist area instead of putting them as big virtually-uninsulated tubes on top of the insulation.
The actual interior of the house is *much* better insulated than it was before that, with the foamboard installed beween wallboard and cinderblock outer walls, and the foot-thick insulation now in the joist area...but the A/C is much less efficient than before.
The actual unit is probably better because of the damage done to the compressor of the old one by the installer that they never fixed, but the new one being on the hot roof in the sun instead of in the shade of the trees, so that all the air it sucks in to do the heat transfer is *already* very very hot, and the duct coming out the side of it to go thru the roof into the house as well as the unit itself being in the direct sun all the time heating that up (and all the air passing thru it), is not helpful.
Being on the roof it also makes the whole house thrum whenever it's running, and that is super annoying when I'm awake, and often wakes me up from what sleep I manage to get.
amber
did you ask the HVAC guys how much $$$$ to move it into the shade?
I didn't get a say in it. (I rent).
If I did it woulda stayed where it was, as it wasn't damaged in the fire and didn't need replacing.
Started taking out the 2 test ac's. 7 years of testing :bigthumb:
the 2017 Haier is not cooling as good as the 2003 Haier. But I don't recall comparing the evaporator temps in 2017 as it was just a test.:rolleyes: And the 2003 Haier has a clogged drain and it was working on the backup drain. I could not get to it to clean, as it was just a test :rolleyes:.
I'm surprised there is sand in the bottom of the condenser exit. I guess on some windy days it got blown in.
Rust- not serious but it looks like it was outside for 2 or 3 years.
will have a closer look once I get them out.
Built a T duct to divide the air BR vs rest of house.
Then I realized how easy it would be to use a Coleman cooler that I got for free on trash day. Missing wheels, but nice :bigthumb:
Being well insulated it should avoid condensation in the morning when the humidity is near 100% (in the attic).
So if mine is damp, I'll switch over to it.
Quick test of new ac system :bigthumb: ducts 54F-58F fan on medium speed. rooms 75, outside 78. Plan was to run for 1 hr,but it got too cold so only 25 min. Might need a t-stat on this one.
Changes from test set up that was used for 7 years:
1. entire supply ductwork replaced, no more using the old attic plenum.
2. old return ducts no longer used.
3. hall duct runs to LR with on/off vent that is easy to reach.
4. large fiberglass condensate drip pan with new fitting and line. Not sure if it will drip much since the new ac has a slinger that throws the cold condensate onto the warm condenser to improve efficiency.
thanks for reading!
here is the 2025 new ac
got a free heater on trash day. had a bad on/off switch. 3 yrs old Walmart 34.99 works great :bigthumb:
see the ac vent above it? got 4 on trash day a few years ago. all 4 now installed :bigthumb:
Here is a video of the only other similar system, that I could find. Go to 16:00 and watch how he connected the ducts :bigthumb:
hooked up my new blue t-stat (paid $2.36 in 2017)
that water slinger works amazing - no water in the pan. it all hits the condenser and evaporates :bigthumb:
so if you remember back in 2017 my neighbor paid $6000 for a new HP. variable speed.
so it looks like the whole system is being replaced! I bet the new one costs more, and I can't wait to hear what he paid.
Update on my neighbor. new Heat Pump/AC $12,800.
fins fell off old unit from salt air. he says 9 years old.
was still working BUT he believed the sales pitch that it might only last another year 🥵.
Well, he didn't ask me,
i've seen them working 30 years old and no fins. sure it is less efficient,
I'd just watch the bills and see if it makes sense to replace. 4% interest on 12,800 is $500/yr, can cover the bills easily.
update on my new $241 ac, 93 today working great, 78F and 49% humidity. :bigthumb:
(not using the LR, so off in there)
Used to read your thread but was off for a year or two. Used to think what is he doing. Now believe that you have been on the right track all the while. AC has been on the forefront of my mind for over ten years now and have moved in with my mother to take care of her, can not hardly take care of myself lol.
Live in San Antonio, Texas, down here we not only battle heat but high humidity. If you achieve 45-50% humidity you are doing good. The lower the humidity the higher tempter you will be comfortable with. My house will go to 70% if not watched close. Do different things to get it back down.
Was in the process of installing minisplits in the house to replace the central AC main reason was every year is hotter and cost per Kw is going up. So the electric bill climbs every summer. The last bill with the central AC was $225, the average here is $400. We try to keep it under $200. I believe that Central AC's waste to much money same tonnage of minisplits would save 30% of cooling cost.
Wanted to share about a new window AC that was bought last year when the central AC stopped working at the end of Summer.
The search found a 12000btu LG unit that used 7.8a. This is 30% less than other units. It is using the new refrigerant R-32 and R-454B and compressor. Homedepot had it so it cost more $500. Unit is 9 months old this year. has energy saving feature that is better than others. Most wait until unit gets room tempter to turn back on this one samples the Air every few mins which keeps the room tempter more even. The last LG window unit is a 6000btu in the Gurage over 10yr old and still works.
Currently believe that the typical AC systems have had their day like ICE. The issues abound, my mothers AC system had flexible ducts in the attic and had to blow air up to 30ft. My mother told me of $500 electric bills with this unit. We kept the tempter at 78-79 deg to keep the bill around $200 that became impossible.
