Hmm, one of my posts seems to have gone missing.
Anyway, John (JRP3) pm'd me, and since it was a general question, it might be better to answer it here. John was asking for more info about using wireless for cell level communications inside a BMS.
Wireless is always going to cost more, in development time and in manufacturing cost, than a wire and not be as good, except in special circumstances. There are also regulatory hurdles to overcome. What we have to ask is whether any such special circumstances apply here. Where wireless works is when one or more ends of the link is mobile, if running a wire is difficult, if the device in question has to communicate with many other devices, if the system is constantly being reconfigured, etc, etc.
Generally none of these things apply to a cell inside a pack. Moreover, the cells have to have power wires connected, so wiring up the BMS signals isn't a big deal. What might make it worth looking at wireless is if very expensive cells have to be tracked, if external devices need to check on the cells, if there is a lot of swapping in and out of cells, etc, etc. But even then, wireless cell connectivity has to be compared with wiring the cells to master unit and using wireless from there.
I wouldn't rule it out, but my guess is its not worth doing unless you identify a need for an external device to talk to an individual high value cell. That could happen as part of systems for EV infrastructure, especially if batteries are leased, but that is getting way beyond normal BMS functions.
Another thing to remember is that a wireless link is never 100% reliable. More than anything else it is prone to work on the bench and fail in the field. A lot of my consultancy work is with people who have a wireless system that works 90% of the time, when they really needed 99.9%.
To paraphrase something often quoted on ES. You can have any two out of this three:
- Low manufacturing cost
Low design cost
It working properly.
There is some work going on towards using frequencies around 50 to 100 GHz for very short range data links inside electronic units, perhaps even from one side to the other of an IC. That might be neat for cell level communications, but I don't think its ready yet.
HTH,
Nick
