I have a 12S Enerdel battery that I purchased from Major on the forum, great guy to deal with by the way!
I want to hook two Celllog8s to the pack. For the second Celllog8s do I connect the negative (first) lead to cell 9 negative (also cell 8 positive) or do I connect that to the cell 0 (aka gnd) connection and the second lead to cell 9 negative? I assume the former as otherwise the Celllog would measure the voltage from 0-8 rather then just cell 9 but I don't have a schematic of the celllog and want to verify.
In a similar vein I want to hook up two BC168 chargers to simultaneously charge the pack. I have two isolated DC supplies to power each BC168 separately. Again, does the negative (first) lead of the second BC168 go to cell 0 (gnd) or to the negative lead on cell 7? By the way, has anyone actually done this with the BC168? Can it handle being wired together like this?
And thirdly, if I buy two 6s standard balance chargers that can charge through mains (say CellPro 6s), is it possible to hook these up on the pack together in a similar way? If so, what do you do with the mains leads on the second charger?
Thanks,
Tom
Thanks,
Tom
