speedmd
Write it in chinese to show some respect and most likely they will respect the wish a bit more. :wink:
I will be passing this on to my contact with Bafang (who speaks and reads English excellently). I would suggest you start a new thread with your connector or parameter questions. More users are learning about the bikes, and probably will give better answers than the factory.flyingcubic said:does somebody from Bafang read this Thread?
I would like to get information about a connector or how to connect to change some parameters
谢谢,但谷歌翻译是说不好翻译在中国(或使我的中国贸易伙伴说)。除了八方代表讲流利的英语。speedmd said:Write it in chinese to show some respect and most likely they will respect the wish a bit more. :wink:
The PAS is built in, but you can buy the motors with Thumb Throttle (TT). However, the appeal of the design is that it assists pedalling, not making a bicycle into a moped. While the 750W may give sufficient boost going up a 15 degree hill to drive a bike like a moped, the point of PAS design is pedal assist, meaning you still have to apply power to the crank.Grey beard said:I know this is early in the production cycle, and we can't expect a "one size fits all". The PAS is worthless to me, and many of my pears that could be converted to riding an electric bike. I'm 70 yrs old with a bad knee, and can't get it fixed since O-care took $750,000,000,000 out of my Medicare and we can't get knee surgery right now.
I will need a throttle only system, be it twist or lever, but 100% throttle as I can't really put much through the cranks.
If you've already got that, please excuse this post.
Thanks for an excellent post.--freeride-- said:Wishlist:
14. Software and a programming cable to configure the motor to our wishes or a setup like the one I mentioned.
15. In Europe we need an option to make the throttle only work when PASS is on, otherwise it is illegal to ride with a throttle. That means if you stop pedaling with throttle on the motor will cut off. You only get Power from the motor if you are under 6km/h (starting aid) or pedaling!
16. There is a soft start in the system, that makes the motor start up soft. That is ok, but the soft start causes a delay of 2seconds when I go full throttle and release throttle. That is much to long, the motor cut off needs to be immediatly without any delay!
Better use a smaller phase current limit, so the motor won't overheat and the transmission does not see huge peaks at the start.
Thats it for Software stuff, I really would like to have an Software interface to play around with parameters and an Euro legal setup!
I only have one mechanical issue.
17. More magnets for the Pass sensor. Only two is not enough. A cut-off at Pedal stop under 0.25s would be very nice. Why not use 8 or even 12 magnets.
If you have any questions feel free to contact me. I would love to provide a good euro-setup!
greenspark said:Wishlist #11 More gears on front chain ring.
Currently 46 and 48 tooth is offered. Originally the specs called for a wider range, starting at 36 teeth. This is probably due to the "bump" that hides the internal gear or chain that connects the motor and the bottom bracket. The most desirable would be to allow the bikes current chainring and crank to be used, which would mean no changing of chain length, and retaining the original look. This would require re-engineering and probably would not come until a second release of the motor.
Or even better as greenspark says allowing the original chainrings of the bike.
joshseitz said:Or even better as greenspark says allowing the original chainrings of the bike.
It seems like this could be accomplished if Bafang chose to drive the LEFT side of the bottom bracket, leaving the right side with a standard square taper (or better yet splined) BB shaft on which you could mount a standard single, double, or triple crank.
swiss said:joshseitz said:Or even better as greenspark says allowing the original chainrings of the bike.
Joshseitz, great idea to drive the LEFT side! What do other technical experts think about this idea? Is this makeable without bigger problems? Using the original chain and chainrings and the fact of an unchanged chainline would be perfect and make the mounting of the middrive once more much easier.
Those of you being in contact with Bafang/8-Fun, pls. ask them what they think about this. I am aware that customers got the tendency to ask for dreams of which realization costs a lot and brings not much. This case is different. This would really improve the product in general and also open the huge market of mountain-biking for Bafang.
Btw I have just seen in the "New Bafang Crank-drives" thread , that our member Kepler, who has my biggest respect, thinks that the original single front-chainring is good enough to climb steepest hills. This might be the case on steep streets, but not on rough steep singletrails, which you can't (or should not...) climb with the speed of a motocross-bike.
lazy_mosquito said:hi Freeride
i think that sums it up, maybe one item to add. Make the display detachable maybe even as kind of ignition key. In that way they can't vandalise or steal the display.
I am wondering how to explain how i would like to drive the e-bike but i think this explains it:
I would like to have a steady ideal crank speed (70-90 rpm) (the engine is now running at ideal speed)
The speed of the bike would be changed by changing gear
The % of assistance is arranged by the PAS-level and not by the rpm of the cranks.
the throttle would override the PAS.
swiss said:Btw I have just seen in the "New Bafang Crank-drives" thread , that our member Kepler, who has my biggest respect, thinks that the original single front-chainring is good enough to climb steepest hills. This might be the case on steep streets, but not on rough steep singletrails, which you can't (or should not...) climb with the speed of a motocross-bike.
Just a qualifier here.Kepler said:I don't agree with 100% throttle override on all PAS settings. IMO, it is just too brutal with the Bafang's touchy throttle. I prefer to keep the assist low, pedal hard, and mash the throttle when needed. 100% throttle would be a nightmare when climbing with a 32 or 34 tooth and the 1150 Watts that this drive pumps out. IMO I think the Bafang engineers have it right with the way they have setup the throttle. I seem to be in a minority with this view though![]()
Kepler said:swiss said:Btw I have just seen in the "New Bafang Crank-drives" thread , that our member Kepler, who has my biggest respect, thinks that the original single front-chainring is good enough to climb steepest hills. This might be the case on steep streets, but not on rough steep singletrails, which you can't (or should not...) climb with the speed of a motocross-bike.
Firstly thank you for the complement. With regards to the above, I agree there would some super steep technical single trail that won't work with the 48 tooth however most trails that sane people will attempt are rideable with the 48 tooth. Freeride I am tipping is a better rider then the average Ebike rider and is looking for ultimate performance and as such I can understand why he has gone for the gear selection he is using. I am a reasonable rider but being in my 50's, common sense now overtakes bravery so I don't go too crazy with the single track I ride. That being said, on my last ride with friends, I got up everything we attempted while others needed to drag their bikes up. No disrespect to my riding buddies who ride well, just setting a picture.
I mostly use setting 5 out of 9 and gear down to a 32 tooth. Under load, the bike travels at about 5 kph up steep technical stuff which might be a little quick but you need excellent balance to ride much slower then that.
This brings me to another item. I don't agree with 100% throttle override on all PAS settings. IMO, it is just too brutal with the Bafang's touchy throttle. I prefer to keep the assist low, pedal hard, and mash the throttle when needed. 100% throttle would be a nightmare when climbing with a 32 or 34 tooth and the 1150 Watts that this drive pumps out. IMO I think the Bafang engineers have it right with the way they have setup the throttle. I seem to be in a minority with this view though![]()
Kepler said:This brings me to another item. I don't agree with 100% throttle override on all PAS settings. IMO, it is just too brutal with the Bafang's touchy throttle. I prefer to keep the assist low, pedal hard, and mash the throttle when needed. 100% throttle would be a nightmare when climbing with a 32 or 34 tooth and the 1150 Watts that this drive pumps out. IMO I think the Bafang engineers have it right with the way they have setup the throttle. I seem to be in a minority with this view though![]()
+1 here.pjgold said:A built in cadence sensor on the display would be a nice feature which would also aid novice riders in correct gear selection. An up/down arrow, rpm number or both would be perfect.
