I have a Juiced 'Camp Scrambler' that was working fine untill last summer but now it has an issue.
https://www.juicedbikes.com/products/scrambler
First a little Info: 52v 13ah, throttle speed limited to 20mph and 75% power output via stock controller, pedal assist speed 28mph and feels more nippy, especially on race mode.
However around last summer I noticed my battery was starting to not get me the range I was used to (3rd year of ownership)
Also, around the same time I changed the disk brake pads and they rubbed quite a bit and I just rode it out till they wore down enough, which ended up being a lot longer than expected so motor may have had a minor bit of rubbing/friction/stress, the bike had a gradual decline but faster over the last year than the previous 2.
Right now my bike behaves like this: throttle still works the same (aside from about half battery capacity now), pedal assist works fine on on a flat or downhill but when going uphill it cuts in and out every second or so ON/OFF/ON/OFF so you can't get up a hill. It feels like the bike has lost the ability to take load? as its only going up hills this happens
I've narrowed down to PAS SENSOR, BATTERY, or HUB MOTOR being the problem, if anyone can give me their opinion or suggest a way I can diagnose the fault myself that would be great!
