working for performant pulse motor
legerme1955
Hello, i am new on board. I started 2 years ago with the idea to add a littel over to mi bike to left mi solar panel power on mi e-bike. Many of your´s will laugh!Today after a big amount of time and money i beleve on reaching the over. the new design and new electronics will allow me to get 80% effi. on mi pulse motor and with help croosing the lentz effect. May be some of you got better results or claim they got an over running( i dont talk about Bedini engines) a real performant pulse motor. I beleve in pulse motors more than the best ultra performant cicso australian brushless motors. Does somebody got an ultraperformant pulse motor? may be whe can share some knowlwedge? I am french and i live in Barcelona Spain, best regards
Hello some pic´s about the engine. The sistem uses a push pull innovative function :idea: ; it means that a dc pulse is gived to the coil and push the south neo , for example , and still ``on´´ untill the following north neo´s reach´s the photo sensor, then the driver reverses polarity coil´s and push the north neo again intil the south reachs again. This way allow to get more torque and less consumption, The generator, an bique brusless e-bike, is built-in the rotor and used as bearing shaft. 6 neo´s are disposed radially at 60 deg, This machine is a protoype and is not very well design and built , and need´s 3 coils more to get a maximum performance but on this way i got like 38 % of efficiency with the following results: 110 v, dc 1,1 amp input on coil´s and 15 v 2,5 amp output on gen with 2x12v bulbs load. The cynetic force was really important and push ne up to upgrade this machine using 2 aluminium rotor disks and 6 powerfull coils radially built in the center and 12 neo´s disposed at 60 deg. Actually i am working on a resistor´s drived array to cross the lentz´ effect who provoque a signifiant deceasing rpm when you turn on the load, Well i hope you enjoy and i can share more info if some body is interested. Best whishes, and excuse mi english, i am french :D
v-twin electric motor... OK, we can check that one off :)
http://www.youtube.com/watch?feature=player_detailpage&v=7lpe3lr3R2s#t=27s YOU CAN WACHT THE MOTOR RUNING ON THE FIRST TEST.
"IN THE WAY TO AN OVER UNITY. PERFORMANT PULSE MOTOR PUSH-PULL SYSTEM 105 WAT IN 38WAT OUT."
[youtube]vcecQ7sUDpQ[/youtube]
garbage??? why, most people are working in performant pulse motors, on the way to reach the cop 1 , why not ? i got mi doubts about but may be ; the border i to cross the lentz effect ! and spend time on research.
