I don't know why Thud likes Wye for his race motor instead of Delta, but...he has built and raced many different motor combinations.
"Re-wind of a turnigy 80/100 (Now-tutorial w/Video)" (Thud, 17 pages)
https://endless-sphere.com/forums/viewtopic.php?f=30&t=20618
So far, I haven't built a better motor & controller set up than the 6-turn, 2-in hand, 14G, dlrk/wye terminated motor...run the thing with a 12 or 18-FET xie-chang with a 6-Kw limit on 20S LiPo cells & you will not find a better RC power combination [with external hall sensors].
Controller settings:
Use Xpd in the tech section to flash settings
Do not solder the shunt (& throw all the calibration out the window)
Do the math with your voltage to arrive @ 6kw @ use that for battery amps.
Set the phase current conservatively (start with battery amps) & make small increases untill your happy with your accelleration, or the controller starts to show some heat.
Most importantly set the block time to zero.
This method has been tested on the race track & in the neighborhoods....you can drain a 25ah pack without overheating controllers or motors from my experience.
