XLD XunLiDa 1500w 36v/48v blues
Item#866C-18 Code# 201907
I am trying to work this wiring out so I don't blow this unit when I get the batteries even though it says it is rated to 50Amps... the Kit did not come with one scrap of paper even in chines I could have worked it out.... if the Picture was in colour Even have people that understand chines read it out....
What specifically is your question?
I thought that was obvious I was looking to see if anyone knows where I can get a Wiring plug code so I know which plug goes where so I don't blow it up when I hook it up.
Ah, no it wasn't obvious. Clear direct questions are best, when clear direct answers are required.
If the info in the Xunlida threads like the other two in this list
https://endless-sphere.com/forums/search.php?keywords=xunlida&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
doesn't help, then take at least one clear picture in good lighting as close-up as you can of the controller with the wires and connectors fanned out so they are easily distinguishable from each other.
Attach the picture to your reply using the Attachments tab, so that anyone that can see the post can see the picture(s).
Then we can make educated guesses as to which connectors perform which functions, based on existing Xunlida posts.
Alternately you can ask the seller you bought it from for a link to their connection diagram. If they don't have one, you could check with other sellers of the Xunlida controllers to see if any of them have a wiring diagram that matches yours.
I think the blue-black-red connector is the PAS plug, the yellow-black might be the High brake, the brown-black might be the Reverse but I'm not sure. I also have no idea what the plug coming off the Motor Hall sensor is.... there was not a scrap of paper that came with this kit... just the Hardware. Just want to get this worked out before the rear wheel arrives...
