I'd just use a thin (1/16" to 3/32") disc of aluminum, about 7" in dia. (depending on motor size) and drill a center hole for the axle. You'll have to make some relief cuts in the disc so it goes past the frame tubes, or fork tube, so the disc sits flat against the drop-out. Even with a rear disc brake, you should be able to fit 4 small CPU fans out side the the rear triangle. As far as the hole for the fans goes, I planned to drill many 5/16" holes where the fans mount, thus cooling the air as it pass through the holes in the aluminum disc.HAL9000v2.0 said:where would you put those fans?
Sorry, what chart ? Blessings, Snow CrowHAL9000v2.0 said:But if you look at my chart you will see that cooling the case from outside solve just a minor problem. Heat transfer inside motor is realy bad.
Ok, I looked at your chart and your plan for cooling. The problem is this, (I had to dig out my physics book :wink: ) the thermal conductivity of Copper is 2660 k (k = Btu x in./ft sq. x h x degrees FahrenheitHAL9000v2.0 said:http://www.endless-sphere.com/forums/viewtopic.php?p=92720#p92720
disndat said:Ebike version 2-specs 5304 on 20"rear with 72v9ah of A123s,full suspension gary fisher"king fisher" bike with 3" chopper tires on both the front and rear.Sorry for the bad pic-its camera phone![]()
Zoot Katz said:Nothing to see here, folks. Move along.
Early 80's Araya CroMo mixte frame "Mountain Touring Bike" gifted by a neighbour Jan 1st, 2006... As it sits it looks like shit but still attracts attention..
Stevil_Knevil said:Zoot Katz said:Nothing to see here, folks. Move along.
If by, "shit" you meant wicked-cool, then ya'.. it looks pretty F' n shitty 8)
Zoot Katz said:Stevil_Knevil said:Zoot Katz said:Nothing to see here, folks. Move along.
Thank you for the compliment. It is a pretty frame and rather unusual for a MTB. The step-through design is convenient when carrying a passenger or top load.
Being my own worst critic, I'm not satisfied with the battery placement. The frame configuration makes it tough to situate the batteries where I want them but that's my fault. After reading this forum I ended up getting larger batteries than originally planned.
I've no complaints about the bike's performance. A 100km range at bicycling speeds suits my needs.
Stevil_Knevil said:The Araya Mixte frame may appear to be slender and delicate, but it has more lateral support than contemporary diamond designs, even better for Xtracycle/longtail builds.
Virtually all of the electric drive has been tucked away in the rear - which is stealthy -- but weight distribution is what, ~30/70?
I imagine that there is an aesthetic/visceral disconnect when you plop-in a 5-series motor @ 48V.. and it could not be shittier :wink:
Well done, Zoot Katz! If you have the wherewithal, please, I would really like to see a separate thread dedicated to this machine.
