Hi!
On Friday I have been on a training for ZEBRA battery type. I guess not many of you are familiar with it and this could be an interesting intermezzo to all "lithium-based" posts
. (see more on http://en.wikipedia.org/wiki/Molten_salt_battery)
It's an alternative to lithium batteries with pretty similar capacity density, however its main components are nickel, sodium chloride (salt) and metal (construction). The most exotic thing on those batteries is that they require pretty high temperatures to work (around 250 degrees Celsius). Therefore every battery is built into special "box", which isolates the battery, so the heating power required is only around 40 W to keep the internal temperature at 250 degrees.
A BMS is also a part of the battery, as it also has to control heating and cooling (sometimes), however ther is no need for single cell balancing. Usual battery packs have voltages around 200, 400 and 600 W and capacities of 40 - 80 Ah. This battery is not so good for small cars, but comes into play for smaller trucks, buses, vans etc. Its lifetime is pretty long (2500 cycles +) and has been proven now as pretty reliable, as some vehicles are running on this battery for more than 15 years.
Regards,
Gregor
Regards,
Gregor
