methods said:
That is awesome man. His machine is at my shop so I presume the stock is too - I did not realize it was already plated with nickle... that is a huge plus. We were just talking about different ways to corrosion-proof the bars including a nickle strike and tin/lead dip.
We will TOTALLY use your stock up!
-methods
Farfle said:
I dropped off a pound and change of some 3mm nickle-plate copper sheet with Luke last time I was down there. (I think its nickle, might be silver, it tins really easy and doesn't corrode AFAIK). If its gone, I have some more I can send ya.
I have this awesome material sitting on my desk at work here, I will bring that over to you in an hour or so when I can get a free minute to take a break.
Also, I want to share a quick story with you on a failed attempt at current management I had using PWM to drive some peltier junction coolers for a forced-temp-chamber I built. I tried driving from like 24v and running a 50% duty cycle at high freq (24khz I think) to these little devices. It behaved nothing like how 12v behaved to them, and in looking at the current waveform, it was actually just 24v spikes with the appropriate current that 24v steady DC makes them pull, followed by virtually zero current in the off-period. This was because the system simply didn't contain any components with enough inductance to have a reasonable time to switch on and off before saturating, and virtually nothing to make the field collapse slowly in the off period to keep current flowing. If I were to drive the exact same 50% duty cycle across something like a contactors coil, or a motor, etc, it would behave pretty much just like I was driving it with 12v rather than 50% duty cycle of 24v, but if the inductance in a circuit approaches zero, you will find you can't even develop any switching scheme to control current with just on-off pulses alone.
I think the ultimate way to do this right, is 1 mosfet of a decent power level, like a 4110 or 4115 or whatever, that drives a separate simple inductor in series with the drain leg that eventually ties up to the output of the other drain legs in parallel once it's done it's job of pre-charging.
Now, since you've got the inductor and a seperate circuit in there, do some clever sh*t with diodes and/or another FET or whatever it takes, and make it so your charger input goes through this circuit, and the inductor is sized large enough to have this same circuit be a current-limiter or whatever to allow you to charge off constant voltage power supplies that don't have a CC mode.
That would be freaking cool.
If you wanted to super show-boat, you would add to that inductor a second multi-tapped inductor, and make a tiny buck-boost topology setup, so you could just plug in your ebike to a very wide range voltage source, from like 5vdc to 100vdc, and it see's what it's got to work with, and bucks or boosts as needed to charge your bike, even if you've got something like an 98vdc pack voltage and just a 12vdc car cigarette lighter port to work with, it could still charge your pack at like 1amp output while drawing in like 10A from your car battery or solar pannel or whatever you've got available over a huge wide range.
But... this would make your tiny on/off switch into something that is like 3lbs and requires a mounting bracket or something rather than just being a tiny inline thing, so maybe it's not worth the effort, but I think it would still be pretty cool.
