Steak,
Wish I had caught ya before surgery - I would have tried to remove the puff (AW style) and then sealed them up again and seen if they managed to hold their charge a bit better... If my understanding of the physics of LiPo is right (and I love ES cause if I am wrong, someone smarter than me will come along and correct me) - the air getting into the cell through that hole was actually what was causing the cell voltage on #2 to drop...
Well you did the surgery and it looks pretty darn well done (better than my first disassembly)!
Wineboy,
No worries... break out the HD soldering gun I told ya you would need, AW (I think it was AW, memory goes this time of night) above is 100% right and no worries, we have all done it at some point or another - how are your fingers?
The repair should take about 15 minutes including re-wraping the pack.
To worries about how reliable dinged, damaged, etc stuff is at 1C charge rate and 3C discharge... I had a pack bounce off the rear of my 20" nova about a week ago (18S2P) at about 30mph as I made a left turn through what I can only describe as Asphault Mogules (to my little 20" tires)... the pack was in a topeak handlebar bag I converted to a trunk (sort of)... When the bag hit the ground the pack came out of the bag and bounced and slid into a curb. I thought I was done for... ran to the pack to get it out of the road and waited, waited, waited for it to get warm, hot and catch fire - this thing has physical dents in some of the cells... nothing happened.
Put the pack back on the bike and resumed my ride. Upon returning I checked for punctures, there was a tiny little one.. sealed it with glue, checked the balance it was ok and so I charged it at 1/2 C - now 325 miles (and about 10 cycles) later - the cells all hold perfectly at 4.15/4.16 after even a full 24hr on the shelf, no puffing and no reduced capacity.
I'm beginning to wonder if all the hype about Lipo being "delicate" is bs or at best just a fact of yesterday which no longer holds true but... is still carried on as truth?
Dogman's 4S is due tommorow with 2 EMS shipments from HK (another 18S4P worth of 6S Turnigy Lipo) - which brings me to my final comment of the evening... After testing the Flightmax and the Turnigy 6S 5AH, the Turnigy will deliver more MAH (because it's under rated) but they are equally capable of 20-30C and if building parallel packs, the flight max are superb ( a bit smaller than the turnigys ) but for single P ebike packs of 5AH... I'm sticking with turnigy for those
-Mike
