El_Steak
Nooooo!voicecoils said:When are you taking orders!?![]()
They are a biatch to make. Took me an entire Saturday afternoon just to make 4 of them
The range of opinions I found on fuses in ebike applications is very wide. I raised that issue back in January and got opinions ranging from "Fuses are for wussies"
The conclusions that I drew from those posts and others here were:
1- The fuse is there to protect the battery against your stupidity when monkeying around with your wiring (happens a lot with RC Lipo packs)
2- The fuse is not a substitute for current limiting. It should be rated high enough so it never blows when you ride your bike hard.
3- The fuse should be rated low enough so it does blow when you act in a stupid fashion as stated in point 1
My controller is rated at 100 amps. In reality, it will peak above 200A for spikes so I guestimated that a fuse rated at 200A would be a fair compromise between point 2 and 3. In retrospect, maybe 125A or 150A would have been sufficient, but the only way to know would be to test it out by shorting my pack and you can bet I won't try it
Its also important to note that the rating of a fuse by itself is not enough information. There are other important factors such as its tolerance and trip time. This document contains good information on the tolerance and trip time characteristics of different types of fuse (MAXI, ANL, AGC, etc.)
